If a theme component (or theme) is selected in a wizard, the CSS is not applied to the wizard when it is run.
I was sure that this was already reported in the past, but I can’t find it anywhere. It has been alluded to here:
As @jimkleiber has stated, the workaround is to put the relevant CSS in a theme component which is applied to the whole site. This means that it won’t be applied per wizard, which limits it a little.
