With the latest CWP and Locations plugins, on Tests-Passed,
When these occur:
- a Locations Field is configured
- this is presented in a simple Wizard
- the location input sub-fields are completed
- the Find Address button is pressed
i.e:
As you can see above, only 2 options are visible without scrolling.
It would be better with 5+.
Note: in other contexts with the Locations plugin they are dynamic and can accomodate up to 10+ (which is probably overkill)
