With the latest CWP and Locations plugins, on Tests-Passed,
When these occur:
- a Locations Field is configured
- this presented in a simple Wizard
- the site (locations plugin) setting
location_input_fields_enabledis unchecked
This happens
- The user is still presented with Input Fields in the Wizard
While Location Input Fields can be helpful, this prevents the use of an unstructured Address field (which is what you get elsewhere with the Locations plugin when that setting is unchecked).
I believe that this should respect the location_input_fields_enabled
