With the latest CWP and Locations plugins, on Tests-Passed,
When these occur:
- a Locations Field is configured
- this presented in a simple Wizard
- there is more than one Input Field
It is impossible to progress in the Wizard unless there is something in each Input Field:
This makes absolutley no sense, as only one field is required to use the Find Address button, which then gives a desired result. This will be a source of much frustration to users (especially if they do NOT want a precise address).
The regular use of the Location Pluging does not mandate more than one of these fields.
Note:
The mandatory setting of the Wizard Location Field applies to whether an address is chosen (this is highly appropriate).
