Since yesterday’s update (currently updated to 3.5.0.beta2-dev [ad992d7b2d], the plugin is not properly registering and even if applied to a category won’t be called when pressing New topic. And at the same time it will prevent posting the default template topic.
Hello @Tolriq,
Apologies since I wasn’t aware of your topic reporting this issue. A fix is on the way:
No problems, thanks a lot.
This has been fixed on the latest version of the plugin. Thanks for the report and your patience.
