Wizard field edits not saving
Hello!
We’ve been running into an issue with our wizards recently. We’re running discourse v3.1.0.beta2 and wizard plugin v2.2.2
No matter the wizard or step or step type, we can not get any of the field edits to save.
Ex: I’ll check the Counter checkbox, scroll down and click Save, and going back to the field will show Counter as unchecked.
From what I can tell, it’s not an issue on our end. Thanks for any/all help in advance!
Sorry you are hitting some trouble.
But any reason why you are not on 3.1.0.beta3 & CW 2.3.0 yet?
It’s very difficult for us to support trailing versions.
Can you please update both the plugin and the core Discourse when you are able and retry?
Please confirm whether or not that solves your issue.
Once you’ve done that and if you are still having a problem, please share your javascript console output and any obvious errors in logs.
No reason, but this was the issue! Updating to beta3 fixed all issues, from what I can tell.
Thanks for the help!
