Warnings in console on 3.3.0
Plugin 9f6e60a
Discourse 3.3.0
To prevent errors in tests, add a `pluginId` key to your `modifyClass` call. This will ensure the modification is only applied once.
"route:user-private-messages-assigned" was not found by modifyClass
Unfortunately, this plugin is a ways down my priority list and it’s unlikely to receive any love in the near term as I don’t really have the bandwidth. I’m going to mark it as broken for now.
#wontfix
Is it actually broken? Or are these just warnings?
These warnings are not indicative of it being broken per se, but I wouldn’t use it. It will likely not work properly.
Fixes!!! Discourse 3.3 compatibility by communiteq · Pull Request #17 · paviliondev/discourse-tickets · GitHub
@angus can you please merge?
I will work on polishing some more things in the upcoming week(s) but at least it’s working again now.
Thank you!
