Users are not redirected to wizards and can't access them even though permitted users are set to ensure trust level >=0 which means everyone.
Discourse Version: v2026.8.0-latest +86
Plugin Commit: 286103f
user clicks new topic and it doesnt redirect them to a wizard
if they get the link for the wizard it says its private or doesnt exist
also when I set the groups in the permitted part of a custom wizard’s settings it doesn’t save em or atleast it doesn’t appear to show that it saved them for some reason it only appears in the json and not actually in the browser where it should indicate that the setting is saved
i mean you need to create a space station 14 account to log in
here is an example link to a wizard
saving perm
https://imgur.com/YcKTFz6
after pressing save
https://imgur.com/jT2lZu1
this is what the user sees
https://imgur.com/a/PUCv1bU
regardless what i set in the permitted section users still cant see the wizards or access them in any way
Anyways this was an issue for quite literally few hours. We will probably roll back to a backup.
