Discourse Version: latest-release +355
Plugin Commit: c9d76848
click the upload button in a composer field, select a file and nothing happens
Not sure if this will work, seems to be freezing my browser
This is the only error that shows up in the logs (nothing in console), may be a conflict with the translation plugin:
Job exception: Failed to open TCP connection to 40.64.128.194:443 (Connection refused - connect(2) for “40.64.128.194” port 443)
net-http-0.4.1/lib/net/http.rb:1603:in initialize' net-http-0.4.1/lib/net/http.rb:1603:in open’
net-http-0.4.1/lib/net/http.rb:1603:in block in connect' timeout-0.4.1/lib/timeout.rb:186:in block in timeout’
timeout-0.4.1/lib/timeout.rb:193:in timeout' net-http-0.4.1/lib/net/http.rb:1601:in connect’
/var/www/discourse/lib/final_destination/http.rb:27:in block in connect' /var/www/discourse/lib/final_destination/http.rb:17:in each’
/var/www/discourse/lib/final_destination/http.rb:17:in each_with_index' /var/www/discourse/lib/final_destination/http.rb:17:in connect’
net-http-0.4.1/lib/net/http.rb:1580:in do_start' net-http-0.4.1/lib/net/http.rb:1569:in start’
faraday-net_http-3.3.0/lib/faraday/adapter/net_http.rb:111:in request_with_wrapped_block' faraday-net_http-3.3.0/lib/faraday/adapter/net_http.rb:101:in perform_request’
faraday-net_http-3.3.0/lib/faraday/adapter/net_http.rb:65:in block in call' faraday-2.12.0/lib/faraday/adapter.rb:45:in connection’
faraday-net_http-3.3.0/lib/faraday/adapter/net_http.rb:64:in call' faraday-2.12.0/lib/faraday/rack_builder.rb:152:in build_response’
faraday-2.12.0/lib/faraday/connection.rb:452:in run_request' faraday-2.12.0/lib/faraday/connection.rb:280:in post’
/var/www/discourse/plugins/discourse-translator/services/discourse_translator/microsoft.rb:171:in post' /var/www/discourse/plugins/discourse-translator/services/discourse_translator/microsoft.rb:175:in result’
/var/www/discourse/plugins/discourse-translator/services/discourse_translator/microsoft.rb:105:in detect' /var/www/discourse/plugins/discourse-translator/plugin.rb:126:in block in execute’
/var/www/discourse/lib/distributed_mutex.rb:53:in block in synchronize' /var/www/discourse/lib/distributed_mutex.rb:49:in synchronize’
/var/www/discourse/lib/distributed_mutex.rb:49:in synchronize' /var/www/discourse/lib/distributed_mutex.rb:34:in synchronize’
/var/www/discourse/plugins/discourse-translator/plugin.rb:124:in execute' /var/www/discourse/app/jobs/base.rb:322:in block (2 levels) in perform’
rails_multisite-6.1.0/lib/rails_multisite/connection_management/null_instance.rb:49:in with_connection' rails_multisite-6.1.0/lib/rails_multisite/connection_management.rb:21:in with_connection’
/var/www/discourse/app/jobs/base.rb:309:in block in perform' /var/www/discourse/app/jobs/base.rb:305:in each’
/var/www/discourse/app/jobs/base.rb:305:in perform' sidekiq-6.5.12/lib/sidekiq/processor.rb:202:in execute_job’
sidekiq-6.5.12/lib/sidekiq/processor.rb:170:in block (2 levels) in process' sidekiq-6.5.12/lib/sidekiq/middleware/chain.rb:177:in block in invoke’
/var/www/discourse/lib/sidekiq/pausable.rb:132:in call' sidekiq-6.5.12/lib/sidekiq/middleware/chain.rb:179:in block in invoke’
sidekiq-6.5.12/lib/sidekiq/middleware/chain.rb:182:in invoke' sidekiq-6.5.12/lib/sidekiq/processor.rb:169:in block in process’
sidekiq-6.5.12/lib/sidekiq/processor.rb:136:in block (6 levels) in dispatch' sidekiq-6.5.12/lib/sidekiq/job_retry.rb:113:in local’
sidekiq-6.5.12/lib/sidekiq/processor.rb:135:in block (5 levels) in dispatch' sidekiq-6.5.12/lib/sidekiq.rb:44:in block in module:Sidekiq’
sidekiq-6.5.12/lib/sidekiq/processor.rb:131:in block (4 levels) in dispatch' sidekiq-6.5.12/lib/sidekiq/processor.rb:263:in stats’
sidekiq-6.5.12/lib/sidekiq/processor.rb:126:in block (3 levels) in dispatch' sidekiq-6.5.12/lib/sidekiq/job_logger.rb:13:in call’
sidekiq-6.5.12/lib/sidekiq/processor.rb:125:in block (2 levels) in dispatch' sidekiq-6.5.12/lib/sidekiq/job_retry.rb:80:in global’
sidekiq-6.5.12/lib/sidekiq/processor.rb:124:in block in dispatch' sidekiq-6.5.12/lib/sidekiq/job_logger.rb:39:in prepare’
sidekiq-6.5.12/lib/sidekiq/processor.rb:123:in dispatch' sidekiq-6.5.12/lib/sidekiq/processor.rb:168:in process’
sidekiq-6.5.12/lib/sidekiq/processor.rb:78:in process_one' sidekiq-6.5.12/lib/sidekiq/processor.rb:68:in run’
sidekiq-6.5.12/lib/sidekiq/component.rb:8:in watchdog' sidekiq-6.5.12/lib/sidekiq/component.rb:17:in block in safe_thread’
