Timezone glitch after recent Daylight savings switch
Discourse Version: 3.1.0.beta3
Plugin Commit: a56a786
  1. Insert a date/time into a post.
  2. The date/time is incorrect in other timezones (as though DST hasn’t changed last week)
  3. Turn off the Events plugin
  4. The date/time now shows other timezones correctly
https://coop.pavilion.tech/
When I (from NZ) use these dates (same UTC):
[date-range from=2023-04-12T21:00:00 to=2023-04-12T22:00:00 timezone="Pacific/Auckland"]
[date-range from=2023-04-12T11:00:00 to=2023-04-12T12:00:00 timezone="Europe/Amsterdam"]
We get this:
Screenshot 2023-04-08 04.06.58
When the Events plugin is turned off, we get this (i.e. works fine):
Screenshot 2023-04-08 04.06.14
Nothing in logs
This seems to only be an issue when one crosses the equator.
Events / times are displayed okay in the forum locally.
However, local calendar entries from Add to Calendar (both iCal & Google Calendar) show daylight savings time inappropriately and thus are one hour out. Something is definitely awry - in a way that makes this plugin pretty compromised.
Can you elaborate on this? This afternoons org meeting is showing the wrong time for me
I reproduced this here on coop, and just pushed a fix
Yay!!! Brilliant! It is now working well when I test it across all those different uses.
Thank you for addressing this, Angus!
