Now that 3.2 is out, can the stable tag/branch be synced with main please?
Looking at this now …
That’s done @richard, can you please perform a checkout at your convenience?
So main and stable should be the same now right?
(They’re not…
Comparing main...stable · paviliondev/discourse-custom-wizard · GitHub)
No, it was a merge, so things may not look the same commit wise.
there are only two files that are different.
it might make more sense to sync those files?
What this suggests is someone made some kind of manual change in stable after an update in main.
OK @richard that is done, the branches look identical now apart from history (not the best I admit, but all I did was a direct merge)
