Stable canary rebuild fails due to discourse-locations plugin
Discourse Version: Discourse-Stable
Plugin Commit: Patch bump · paviliondev/discourse-locations@3c713a6 · GitHub
Rebuild fails when we rebuild stable with the plugin added to app.yml
https://stable.discourse.pluginmanager.org/
I’ve commented the plugin form app.yml
I, [2022-10-27T10:14:09.293061 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
        94: from /usr/local/bin/bundle:25:in `<main>'
        93: from /usr/local/bin/bundle:25:in `load'
        92: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.5/exe/bundle:36:in `<top (required)>'
        91: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.5/lib/bundler/friendly_errors.rb:103:in `with_friendly_errors'
        90: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.5/exe/bundle:48:in `block in <top (required)>'
        89: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.5/lib/bundler/cli.rb:25:in `start'
        88: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.5/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
        87: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.5/lib/bundler/cli.rb:31:in `dispatch'
        86: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.5/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
        85: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.5/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
        84: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.5/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
        83: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.5/lib/bundler/cli.rb:484:in `exec'
        82: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.5/lib/bundler/cli/exec.rb:23:in `run'
        81: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.5/lib/bundler/cli/exec.rb:58:in `kernel_load'
        80: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.5/lib/bundler/cli/exec.rb:58:in `load'
        79: from /var/www/discourse/vendor/bundle/ruby/2.7.0/bin/rake:25:in `<top (required)>'
        78: from /var/www/discourse/vendor/bundle/ruby/2.7.0/bin/rake:25:in `load'
        77: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
        76: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:80:in `run'
        75: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:186:in `standard_exception_handling'
        74: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:83:in `block in run'
        73: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:110:in `top_level'
        72: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:125:in `run_with_threads'
        71: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `block in top_level'
        70: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `each'
        69: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `block (2 levels) in top_level'
        68: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:160:in `invoke_task'
        67: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:188:in `invoke'
        66: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:199:in `invoke_with_call_chain'
        65: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:199:in `synchronize'
        64: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:218:in `block in invoke_with_call_chain'
        63: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:241:in `invoke_prerequisites'
        62: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:241:in `each'
        61: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:243:in `block in invoke_prerequisites'
        60: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:199:in `invoke_with_call_chain'
        59: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:199:in `synchronize'
        58: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:218:in `block in invoke_with_call_chain'
        57: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:241:in `invoke_prerequisites'
        56: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:241:in `each'
        55: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:243:in `block in invoke_prerequisites'
        54: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:199:in `invoke_with_call_chain'
        53: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:199:in `synchronize'
        52: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
        51: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:in `execute'
        50: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:in `each'
        49: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:in `block in execute'
        48: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.6.1/lib/rails/application.rb:533:in `block in run_tasks_blocks'
        47: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.6.1/lib/rails/application.rb:367:in `require_environment!'
        46: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.6.1/lib/active_support/dependencies.rb:332:in `require'
        45: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.6.1/lib/active_support/dependencies.rb:299:in `load_dependency'
        44: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.6.1/lib/active_support/dependencies.rb:332:in `block in require'
        43: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/zeitwerk-2.6.0/lib/zeitwerk/kernel.rb:35:in `require'
        42: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:31:in `require'
        41: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:in `require_with_bootsnap_lfi'
        40: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/loaded_features_index.rb:88:in `register'
        39: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `block in require_with_bootsnap_lfi'
        38: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `require'
        37: from /var/www/discourse/config/environment.rb:7:in `<main>'
        36: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.6.1/lib/rails/railtie.rb:207:in `method_missing'
        35: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.6.1/lib/rails/railtie.rb:207:in `public_send'
        34: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.6.1/lib/rails/application.rb:391:in `initialize!'
        33: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.6.1/lib/rails/initializable.rb:60:in `run_initializers'
        32: from /usr/local/lib/ruby/2.7.0/tsort.rb:205:in `tsort_each'
        31: from /usr/local/lib/ruby/2.7.0/tsort.rb:226:in `tsort_each'
        30: from /usr/local/lib/ruby/2.7.0/tsort.rb:347:in `each_strongly_connected_component'
        29: from /usr/local/lib/ruby/2.7.0/tsort.rb:347:in `call'
        28: from /usr/local/lib/ruby/2.7.0/tsort.rb:347:in `each'
        27: from /usr/local/lib/ruby/2.7.0/tsort.rb:349:in `block in each_strongly_connected_component'
        26: from /usr/local/lib/ruby/2.7.0/tsort.rb:431:in `each_strongly_connected_component_from'
        25: from /usr/local/lib/ruby/2.7.0/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
        24: from /usr/local/lib/ruby/2.7.0/tsort.rb:228:in `block in tsort_each'
        23: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.6.1/lib/rails/initializable.rb:61:in `block in run_initializers'
        22: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.6.1/lib/rails/initializable.rb:32:in `run'
        21: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.6.1/lib/rails/initializable.rb:32:in `instance_exec'
        20: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.6.1/lib/rails/application/finisher.rb:140:in `block in <module:Finisher>'
        19: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.6.1/lib/active_support/lazy_load_hooks.rb:51:in `run_load_hooks'
        18: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.6.1/lib/active_support/lazy_load_hooks.rb:51:in `each'
        17: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.6.1/lib/active_support/lazy_load_hooks.rb:52:in `block in run_load_hooks'
        16: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.6.1/lib/active_support/lazy_load_hooks.rb:66:in `execute_hook'
        15: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.6.1/lib/active_support/lazy_load_hooks.rb:61:in `with_execution_control'
        14: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.6.1/lib/active_support/lazy_load_hooks.rb:68:in `block in execute_hook'
        13: from /var/www/discourse/config/application.rb:363:in `block in <class:Application>'
        12: from /var/www/discourse/lib/plugin_initialization_guard.rb:5:in `plugin_initialization_guard'
        11: from /var/www/discourse/config/application.rb:364:in `block (2 levels) in <class:Application>'
        10: from /var/www/discourse/config/application.rb:364:in `each'
        9: from /var/www/discourse/lib/plugin/instance.rb:476:in `notify_after_initialize'
        8: from /var/www/discourse/lib/plugin/instance.rb:476:in `each'
        7: from /var/www/discourse/lib/plugin/instance.rb:478:in `block in notify_after_initialize'
        6: from /var/www/discourse/plugins/discourse-custom-wizard/plugin.rb:260:in `block in activate!'
        5: from /var/www/discourse/lib/discourse_event.rb:13:in `trigger'
        4: from /usr/local/lib/ruby/2.7.0/set.rb:328:in `each'
        3: from /usr/local/lib/ruby/2.7.0/set.rb:328:in `each_key'
        2: from /var/www/discourse/lib/discourse_event.rb:14:in `block in trigger'
        1: from /var/www/discourse/lib/plugin/instance.rb:465:in `block in on'
/var/www/discourse/plugins/discourse-locations/plugin.rb:240:in `block in activate!': undefined method `register_callback' for CustomWizard::Action:Class (NoMethodError)
** INCOMPATIBLE PLUGIN **
You are unable to build Discourse due to errors in the plugin at
Please try removing this plugin and rebuilding again!
@merefield See above :point_up:
That commit is a change of version number lol
@angus :thinking:
Might this relate to your recent PR commit?
Specifically this one:
https://github.com/paviliondev/discourse-locations/commit/876a82018037c317055eaf82a70a3e5961bc832d
Is stable running an incompatible version of Custom Wizard? Does something need to be backported?
Shouldn’t this have been a PR btw? :face_with_monocle:
Also, I’m not sure I understand the dashboard here:
This suggests there’s no problem with Stable?
Could it be things only fail when Stable version of Custom Wizard is added to a server with Locations?
Yup, that’s the cause.
Correct.
Yes, it should have, sorry!
@itsbhanusharma I’ll update the stable version of the custom wizard plugin early next week.
In the meantime I’m going to mark the custom wizard plugin as incompatible with stable.
I’ve moved this across to #discourse-custom-wizard:issues and I’m rebuilding stable canary with the custom wizard in the incompatible_plugins folder.
I had commented two plugins on stable canary, feel free to uncomment those if the core problem is now identified.
