If you have the Discourse Chatbot Plugin installed as well, you can simply ask it this.
The alternative is this Data Exploer query. It takes a username and distance, and returns all users who are located within that distance from the user.
It defaults to km, but miles can be used if you are in one of the backward countries in the world that are still imperial…
The use-case is to easily enable the identification of users in a certain area for a local event or grouping.
-- [params]
-- string :username
-- int :distance
-- string :unit = km
-- Define the username and distance in kilometres or miles
WITH target_user AS (
SELECT lu.latitude, lu.longitude
FROM users u
JOIN locations_user lu ON u.id = lu.user_id
WHERE u.username = :username
conversion_factor AS (
SELECT CASE WHEN :unit = 'km' THEN 111.045
WHEN :unit = 'miles' THEN 69.0
END AS factor
-- Select users within the defined distance
SELECT u.username,
ROUND(((point(lu.latitude, lu.longitude) <-> point((SELECT latitude FROM target_user), (SELECT longitude FROM target_user))) * (SELECT factor FROM conversion_factor))::numeric,1) AS distance_in_unit
FROM users u
WHERE (point(lu.latitude, lu.longitude) <-> point((SELECT latitude FROM target_user), (SELECT longitude FROM target_user))) * (SELECT factor FROM conversion_factor) <= :distance
ORDER BY distance_in_unit
