Resolve deprecations (before it breaks)
There are a lot of deprecations showing for the front end code. We can either wait till they break and resolve it under too much time pressure, or act on them right now.
            {"type":"warn","text":"DEPRECATION: Calling transitionTo on a route is deprecated. Use the RouterService instead. [deprecation id: routing.transition-methods] See https://deprecations.emberjs.com/v3.x/#toc_routing-transition-methods for more details."}
            {"type":"warn","text":"[PLUGIN test] Deprecation notice: Defining modals using a controller is deprecated. Use the component-based API instead. (modal: next-session-scheduled) [deprecated since Discourse 3.1] [removal in Discourse 3.2] [deprecation id: discourse.modal-controllers] [info: https://meta.discourse.org/t/268057]"}
            {"type":"warn","text":"DEPRECATION: The `action.type` property path was used in the `discourse/plugins/discourse-custom-wizard/discourse/templates/components/wizard-custom-action.hbs` template without using `this`. This fallback behavior has been deprecated, all properties must be looked up on `this` when used in the template: {{this.action.type}} [deprecation id: this-property-fallback] See https://deprecations.emberjs.com/v3.x#toc_this-property-fallback for more details."}
            {"type":"warn","text":"DEPRECATION: The `action.run_after` property path was used in the `discourse/plugins/discourse-custom-wizard/discourse/templates/components/wizard-custom-action.hbs` template without using `this`. This fallback behavior has been deprecated, all properties must be looked up on `this` when used in the template: {{this.action.run_after}} [deprecation id: this-property-fallback] See https://deprecations.emberjs.com/v3.x#toc_this-property-fallback for more details."}
            {"type":"warn","text":"DEPRECATION: The `action.title` property path was used in the `discourse/plugins/discourse-custom-wizard/discourse/templates/components/wizard-custom-action.hbs` template without using `this`. This fallback behavior has been deprecated, all properties must be looked up on `this` when used in the template: {{this.action.title}} [deprecation id: this-property-fallback] See https://deprecations.emberjs.com/v3.x#toc_this-property-fallback for more details."}
            {"type":"warn","text":"DEPRECATION: The `action.post` property path was used in the `discourse/plugins/discourse-custom-wizard/discourse/templates/components/wizard-custom-action.hbs` template without using `this`. This fallback behavior has been deprecated, all properties must be looked up on `this` when used in the template: {{this.action.post}} [deprecation id: this-property-fallback] See https://deprecations.emberjs.com/v3.x#toc_this-property-fallback for more details."}
            {"type":"warn","text":"DEPRECATION: The `action.post_builder` property path was used in the `discourse/plugins/discourse-custom-wizard/discourse/templates/components/wizard-custom-action.hbs` template without using `this`. This fallback behavior has been deprecated, all properties must be looked up on `this` when used in the template: {{this.action.post_builder}} [deprecation id: this-property-fallback] See https://deprecations.emberjs.com/v3.x#toc_this-property-fallback for more details."}
            {"type":"warn","text":"DEPRECATION: The `action.category` property path was used in the `discourse/plugins/discourse-custom-wizard/discourse/templates/components/wizard-custom-action.hbs` template without using `this`. This fallback behavior has been deprecated, all properties must be looked up on `this` when used in the template: {{this.action.category}} [deprecation id: this-property-fallback] See https://deprecations.emberjs.com/v3.x#toc_this-property-fallback for more details."}
            {"type":"warn","text":"DEPRECATION: The `action.tags` property path was used in the `discourse/plugins/discourse-custom-wizard/discourse/templates/components/wizard-custom-action.hbs` template without using `this`. This fallback behavior has been deprecated, all properties must be looked up on `this` when used in the template: {{this.action.tags}} [deprecation id: this-property-fallback] See https://deprecations.emberjs.com/v3.x#toc_this-property-fallback for more details."}
            {"type":"warn","text":"DEPRECATION: The `action.visible` property path was used in the `discourse/plugins/discourse-custom-wizard/discourse/templates/components/wizard-custom-action.hbs` template without using `this`. This fallback behavior has been deprecated, all properties must be looked up on `this` when used in the template: {{this.action.visible}} [deprecation id: this-property-fallback] See https://deprecations.emberjs.com/v3.x#toc_this-property-fallback for more details."}
            {"type":"warn","text":"DEPRECATION: The `action.custom_fields` property path was used in the `discourse/plugins/discourse-custom-wizard/discourse/templates/components/wizard-custom-action.hbs` template without using `this`. This fallback behavior has been deprecated, all properties must be looked up on `this` when used in the template: {{this.action.custom_fields}} [deprecation id: this-property-fallback] See https://deprecations.emberjs.com/v3.x#toc_this-property-fallback for more details."}
            {"type":"warn","text":"DEPRECATION: The `action.profile_updates` property path was used in the `discourse/plugins/discourse-custom-wizard/discourse/templates/components/wizard-custom-action.hbs` template without using `this`. This fallback behavior has been deprecated, all properties must be looked up on `this` when used in the template: {{this.action.profile_updates}} [deprecation id: this-property-fallback] See https://deprecations.emberjs.com/v3.x#toc_this-property-fallback for more details."}
            {"type":"warn","text":"DEPRECATION: The `action.url` property path was used in the `discourse/plugins/discourse-custom-wizard/discourse/templates/components/wizard-custom-action.hbs` template without using `this`. This fallback behavior has been deprecated, all properties must be looked up on `this` when used in the template: {{this.action.url}} [deprecation id: this-property-fallback] See https://deprecations.emberjs.com/v3.x#toc_this-property-fallback for more details."}
            {"type":"warn","text":"DEPRECATION: The `input.type` property path was used in the `discourse/plugins/discourse-custom-wizard/discourse/templates/components/wizard-mapper-input.hbs` template without using `this`. This fallback behavior has been deprecated, all properties must be looked up on `this` when used in the template: {{this.input.type}} [deprecation id: this-property-fallback] See https://deprecations.emberjs.com/v3.x#toc_this-property-fallback for more details."}
            {"type":"warn","text":"DEPRECATION: The `input` property path was used in the `discourse/plugins/discourse-custom-wizard/discourse/templates/components/wizard-mapper-input.hbs` template without using `this`. This fallback behavior has been deprecated, all properties must be looked up on `this` when used in the template: {{this.input}} [deprecation id: this-property-fallback] See https://deprecations.emberjs.com/v3.x#toc_this-property-fallback for more details."}
            {"type":"warn","text":"DEPRECATION: The `input.output` property path was used in the `discourse/plugins/discourse-custom-wizard/discourse/templates/components/wizard-mapper-input.hbs` template without using `this`. This fallback behavior has been deprecated, all properties must be looked up on `this` when used in the template: {{this.input.output}} [deprecation id: this-property-fallback] See https://deprecations.emberjs.com/v3.x#toc_this-property-fallback for more details."}
            {"type":"warn","text":"DEPRECATION: The `input.output_type` property path was used in the `discourse/plugins/discourse-custom-wizard/discourse/templates/components/wizard-mapper-input.hbs` template without using `this`. This fallback behavior has been deprecated, all properties must be looked up on `this` when used in the template: {{this.input.output_type}} [deprecation id: this-property-fallback] See https://deprecations.emberjs.com/v3.x#toc_this-property-fallback for more details."}
            {"type":"warn","text":"DEPRECATION: The `input.pairs` property path was used in the `discourse/plugins/discourse-custom-wizard/discourse/templates/components/wizard-mapper-input.hbs` template without using `this`. This fallback behavior has been deprecated, all properties must be looked up on `this` when used in the template: {{this.input.pairs}} [deprecation id: this-property-fallback] See https://deprecations.emberjs.com/v3.x#toc_this-property-fallback for more details."}
            {"type":"warn","text":"DEPRECATION: The `input.output_connector` property path was used in the `discourse/plugins/discourse-custom-wizard/discourse/templates/components/wizard-mapper-input.hbs` template without using `this`. This fallback behavior has been deprecated, all properties must be looked up on `this` when used in the template: {{this.input.output_connector}} [deprecation id: this-property-fallback] See https://deprecations.emberjs.com/v3.x#toc_this-property-fallback for more details."}
Assigning this to me.
(changed the assignment from post level to topic level otherwise it breaks reporting)
Thanks. Yeah weird for some reason I couldnā€™t assign at topic level.
Do we need to assign at the post level, or just topic level? Perhaps we should hide the post assign option as Iā€™m sure Iā€™ve done this by mistake too.
There doesnā€™t seem to be a setting to make it just Topic level assigns, but there is an assign-post class so hiding it should be easy.
I think it was early and I was using wrench drop-down instead of the button. :sweat_smile:
Iā€™ve just hidden these with CSS in our theme:
span.extra-buttons button.assign-post {
        display: none;
OK that was quite a lot more than I originally bargained for.
Nonetheless, hereā€™s the PR:
Pending review.
One minor change and this will be merged.
Resolved! //unintentional
Please let me know if you become aware of any negative impact of this change and I will take a look.
Still seeing one
[PLUGIN discourse-custom-wizard] Deprecation notice: Importing getOwner from `discourse-common/lib/get-owner` is deprecated. Use `import { getOwner } from '@ember/application'`, or if you still need the fallback shim, use `import { getOwnerWithFallback } from 'discourse-common/lib/get-owner';`. [deprecated since Discourse 3.2] [deprecation id: discourse.get-owner-with-fallback]
CW 578c92e90e0275677e529d7a488970ae52243ba2
Discourse 76e5a939d4d24c95ddaa6c4f1db1f2bc09330187
Probably a new one
