You can fetch any single topic by inserting into the html the following code:
<% get_topic_view('english-glossary', opts: { include_suggested: false, include_related: false, post_number: 1 }, instance_var: "glossary", set_page_title: true) %>
The data will be stored in a local variable called glossary because it is defined in instance_var. To call the topic_view you use @glossary. You can access and display the data with a similar code as the following:
<% if @glossary.present? %>
<div class="title-container" <% unless mobile_view? %> <% end %>">
<div class="contents canvas">
<h1 title="<%= @glossary.title %>" class="title"><%= @glossary.title %></h1>
<section class="topic-byline">
<div class="date" title="<%= short_date(@glossary.topic.updated_at) %>">
Updated at: <%= short_date(@glossary.topic.updated_at) %>
</div>
</section>
</div>
</div>
<% end %>
<article class="post">
<div class="container">
<section class="post-content canvas">
<%= ::LandingPages::Post.html(@glossary.posts.first).html_safe %>
</section>
<%- if current_user %>
<div class="comment-container">
<div class="comment-footer">
<a class="btn btn-primary" href="/w/glossary-suggestion" targe="_blank">Suggest a term</a>
</div>
</div>
<%- end %>
</div>
</article>
<% end %>
In this case, I use @glossary.topic.updated_at but you can access any other topic property as well.
You can also access the data for an entire list of topics and displaying by using:
<% topic_list(list_opts: { order: 'date', category: 'news', no_definitions: true }, opts: { instance_var: "news"}) %>
<% @news.each do |article| %>
<li style="display: flex; margin:10px">
<a href="<%= article.url %>" class="item" target="_blank">
<div class="item-title">
<%= short_date(article.created_at) %><br>
<%= emoji_codes_to_img(article.fancy_title) %>
</div>
<% if article.image_url.present? %>
<div class="item-image">
<img src="<%= article.image_url %>" />
</div>
<% end %>
</a>
</li>
<% end %>
Hope this helps.
