Discourse Version: v3.2.0.beta3 +450
Plugin Commit: latest, currently uninstalled
Rebuild fails with custom wizard enabled
I, [2023-12-08T02:58:28.187645 #1] INFO – : > cd /var/www/discourse && su discourse -c ‘bundle exec rake db:migrate’
Plugin name is ‘discourse-custom-email-digest-enabled’, but plugin directory is named ‘discourse-custom-email-digest’
rake aborted!
Gem::LoadError: can’t activate discourse_subscription_client-0.1.0.pre15, already activated discourse_subscription_client-0.1.1 (Gem::LoadError)
/var/www/discourse/lib/plugin_gem.rb:25:in load' /var/www/discourse/lib/plugin/instance.rb:848:in
gem’
/var/www/discourse/plugins/discourse-subscription-client/plugin.rb:13:in activate!' /var/www/discourse/lib/plugin/instance.rb:745:in
instance_eval’
/var/www/discourse/lib/plugin/instance.rb:745:in activate!' /var/www/discourse/lib/discourse.rb:347:in
block in activate_plugins!’
/var/www/discourse/lib/discourse.rb:344:in each' /var/www/discourse/lib/discourse.rb:344:in
activate_plugins!’
/var/www/discourse/config/application.rb:227:in block in <class:Application>' /var/www/discourse/lib/plugin.rb:6:in
initialization_guard’
/var/www/discourse/config/application.rb:227:in <class:Application>' /var/www/discourse/config/application.rb:75:in
module:Discourse’
/var/www/discourse/config/application.rb:74:in <top (required)>' <internal:/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb>:38:in
require’
internal:/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb:38:in require' /var/www/discourse/Rakefile:7:in
<top (required)>’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/exe/rake:27:in <top (required)>' /usr/local/bin/bundle:25:in
load’
/usr/local/bin/bundle:25:in `’
(See full trace by running task with --trace)
I, [2023-12-08T02:58:41.050511 #1] INFO – : gem install tokenizers -v 0.3.3 -i /var/www/discourse/plugins/discourse-ai/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed tokenizers-0.3.3-x86_64-linux
1 gem installed
gem install tiktoken_ruby -v 0.0.5 -i /var/www/discourse/plugins/discourse-ai/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed tiktoken_ruby-0.0.5-x86_64-linux
1 gem installed
gem install iso8601 -v 0.13.0 -i /var/www/discourse/plugins/discourse-automation/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed iso8601-0.13.0
1 gem installed
gem install rrule -v 0.4.4 -i /var/www/discourse/plugins/discourse-automation/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed rrule-0.4.4
1 gem installed
gem install rrule -v 0.4.4 -i /var/www/discourse/plugins/discourse-calendar/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
1 gem installed
gem install multipart-post -v 2.3.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed multipart-post-2.3.0
1 gem installed
gem install faraday-multipart -v 1.0.4 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed faraday-multipart-1.0.4
1 gem installed
gem install event_stream_parser -v 1.0.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed event_stream_parser-1.0.0
1 gem installed
gem install ruby-openai -v 6.3.1 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed ruby-openai-6.3.1
1 gem installed
gem install google_search_results -v 2.2.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed google_search_results-2.2.0
1 gem installed
gem install wikipedia-client -v 1.17.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed wikipedia-client-1.17.0
1 gem installed
gem install childprocess -v 4.1.0 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed childprocess-4.1.0
1 gem installed
gem install safe_ruby -v 1.0.4 -i /var/www/discourse/plugins/discourse-chatbot/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed safe_ruby-1.0.4
1 gem installed
gem install liquid -v 5.0.1 -i /var/www/discourse/plugins/discourse-custom-wizard/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed liquid-5.0.1
1 gem installed
gem install discourse_subscription_client -v 0.1.1 -i /var/www/discourse/plugins/discourse-custom-wizard/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed discourse_subscription_client-0.1.1
1 gem installed
gem install discourse_plugin_statistics -v 0.1.0.pre7 -i /var/www/discourse/plugins/discourse-custom-wizard/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed discourse_plugin_statistics-0.1.0.pre7
1 gem installed
gem install geocoder -v 1.8.2 -i /var/www/discourse/plugins/discourse-locations/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed geocoder-1.8.2
1 gem installed
gem install discourse_subscription_client -v 0.1.0.pre15 -i /var/www/discourse/plugins/discourse-subscription-client/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Successfully installed discourse_subscription_client-0.1.0.pre15
1 gem installed
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c ‘bundle exec rake db:migrate’ failed with return #<Process::Status: pid 3704 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn’
exec failed with the params {“cd”=>“$home”, “hook”=>“db_migrate”, “cmd”=>[“su discourse -c ‘bundle exec rake db:migrate’”]}
bootstrap failed with exit code 1
