Problem with discourse_subscription_client gem
Discourse Version: 3.4.1
Plugin Commit: ac347394f966c54f6086832e5a8dae2db9fce468
We have a multisite installation with custom wizard and we are trying to move the forums to a new server.
Source: running Discourse 3.3.3
Destination: running Discourse 3.4.1
Both with the CW and Events plugin
Src: CW 83320e227ce1bb1419bcc33eaa11a5e5d4e5bdc2 Events cff577e4df69010aa6957bc7ef7906e0980b4980
Dest: CW ac347394f966c54f6086832e5a8dae2db9fce468 Events 870dc0ffdc28c0f20eb2e18d4f42feb4a7e6fd7e
When we perform a backup/restore then we run into the following situation:
  • multisite master has migration 20240917131841_add_keys_to_subscription_client_resource.rb
  • restored forum does not have that migration
  • when we try to migrate this happens
ActiveRecord::StatementInvalid: PG::UndefinedColumn: ERROR:  column "access_key_id" of relation "subscription_client_resources" does not exist (ActiveRecord::StatementInvalid)
LINE 1: ...supplier_id", "name", "created_at", "updated_at", "access_ke...
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/db/pg.rb:69:in `exec_params'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql_adapter.rb:894:in `block (2 levels) in exec_no_cache'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:1004:in `block in with_raw_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:976:in `with_raw_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql_adapter.rb:893:in `block in exec_no_cache'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/notifications/instrumenter.rb:58:in `instrument'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:1119:in `log'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql_adapter.rb:892:in `exec_no_cache'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql_adapter.rb:872:in `execute_and_clear'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:66:in `internal_exec_query'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:159:in `exec_insert'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:85:in `exec_insert'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:197:in `insert'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/query_cache.rb:27:in `insert'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/persistence.rb:258:in `block in _insert_record'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:415:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_handling.rb:296:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/persistence.rb:251:in `_insert_record'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/persistence.rb:928:in `block in _create_record'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/persistence.rb:925:in `_create_record'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/counter_cache.rb:201:in `_create_record'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/locking/optimistic.rb:84:in `_create_record'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/encryption/encryptable_record.rb:184:in `_create_record'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/attribute_methods/dirty.rb:240:in `_create_record'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/callbacks.rb:445:in `block in _create_record'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/callbacks.rb:110:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/callbacks.rb:913:in `_run_create_callbacks'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/callbacks.rb:445:in `_create_record'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/timestamp.rb:116:in `_create_record'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/persistence.rb:896:in `create_or_update'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/callbacks.rb:441:in `block in create_or_update'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/callbacks.rb:121:in `block in run_callbacks'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/autosave_association.rb:362:in `around_save_collection_association'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/callbacks.rb:130:in `block in run_callbacks'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/callbacks.rb:141:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/callbacks.rb:913:in `_run_save_callbacks'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/callbacks.rb:441:in `create_or_update'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/timestamp.rb:127:in `create_or_update'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/persistence.rb:426:in `save!'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/validations.rb:54:in `save!'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/transactions.rb:366:in `block in save!'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/transactions.rb:418:in `block (2 levels) in with_transaction_returning_status'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:359:in `transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/transactions.rb:414:in `block in with_transaction_returning_status'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/transactions.rb:410:in `with_transaction_returning_status'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/transactions.rb:366:in `save!'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/suppressor.rb:56:in `save!'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/persistence.rb:55:in `create!'
/var/www/discourse/plugins/discourse-custom-wizard/gems/3.3.3/gems/discourse_subscription_client-0.1.11/lib/discourse_subscription_client/resources.rb:73:in `block in save_resources'
/var/www/discourse/plugins/discourse-custom-wizard/gems/3.3.3/gems/discourse_subscription_client-0.1.11/lib/discourse_subscription_client/resources.rb:64:in `each'
/var/www/discourse/plugins/discourse-custom-wizard/gems/3.3.3/gems/discourse_subscription_client-0.1.11/lib/discourse_subscription_client/resources.rb:64:in `save_resources'
/var/www/discourse/plugins/discourse-custom-wizard/gems/3.3.3/gems/discourse_subscription_client-0.1.11/lib/discourse_subscription_client/resources.rb:29:in `block in find_all'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/transaction.rb:616:in `block in within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/transaction.rb:613:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:361:in `transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/transactions.rb:234:in `block in transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/transactions.rb:233:in `transaction'
/var/www/discourse/plugins/discourse-custom-wizard/gems/3.3.3/gems/discourse_subscription_client-0.1.11/lib/discourse_subscription_client/resources.rb:27:in `find_all'
/var/www/discourse/plugins/discourse-custom-wizard/gems/3.3.3/gems/discourse_subscription_client-0.1.11/lib/discourse_subscription_client/resources.rb:15:in `block in find_all'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management.rb:265:in `block in each_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management.rb:263:in `each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management.rb:263:in `each_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management.rb:21:in `each_connection'
/var/www/discourse/plugins/discourse-custom-wizard/gems/3.3.3/gems/discourse_subscription_client-0.1.11/lib/discourse_subscription_client/resources.rb:14:in `find_all'
/var/www/discourse/plugins/discourse-custom-wizard/gems/3.3.3/gems/discourse_subscription_client-0.1.11/lib/discourse_subscription_client/subscriptions.rb:16:in `update'
/var/www/discourse/plugins/discourse-custom-wizard/gems/3.3.3/gems/discourse_subscription_client-0.1.11/lib/discourse_subscription_client/subscriptions.rb:10:in `update'
/var/www/discourse/plugins/discourse-events/lib/discourse_events/subscription_manager.rb:140:in `perform_update'
/var/www/discourse/plugins/discourse-events/lib/discourse_events/subscription_manager.rb:135:in `setup'
/var/www/discourse/plugins/discourse-events/lib/discourse_events/subscription_manager.rb:122:in `setup'
/var/www/discourse/plugins/discourse-events/plugin.rb:27:in `block in activate!'
/var/www/discourse/lib/plugin/instance.rb:605:in `block in on'
/var/www/discourse/lib/discourse_event.rb:12:in `block in trigger'
/var/www/discourse/lib/discourse_event.rb:12:in `trigger'
/var/www/discourse/plugins/discourse-custom-wizard/gems/3.3.3/gems/discourse_subscription_client-0.1.11/lib/discourse_subscription_client/engine.rb:74:in `block in <class:Engine>'
https://pavilionedu.discoursehosting.net
see above
Actually, now I look at the backtrace, this might be more of a problem with the events plugin. It tries to update (line 27 of plugin.rb) also when it is called to run migrations.
This line should only be ran if Discourse.running_in_rack?
EDIT yes I patched events and that fixes it.
Thanks for the report and suggested fix. I’ve applied it to the events plugin
