Image preview is now fixed, but I cannot submit the form, red box is shown around container without any error. I checked wizard settings and could not find the culprit:
To repro: Open https://cablogstaging.discoursehosting.net/admin/wizards/wizard/test_2_9 and type any text into composer and hit “Fertig”. Red box appears
Submitting works when composer is empty (0/0 chars) though.
Video demo of issue:
Logs:
/var/www/discourse/app/controllers/static_controller.rb:160:in `read'
/var/www/discourse/app/controllers/static_controller.rb:160:in `block (2 levels) in favicon'
/var/www/discourse/lib/distributed_memoizer.rb:16:in `block in memoize'
/var/www/discourse/lib/distributed_mutex.rb:57:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:53:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:38:in `synchronize'
/var/www/discourse/lib/distributed_memoizer.rb:12:in `memoize'
/var/www/discourse/app/controllers/static_controller.rb:138:in `block in favicon'
/var/www/discourse/lib/hijack.rb:56:in `instance_eval'
/var/www/discourse/lib/hijack.rb:56:in `block in hijack'
/var/www/discourse/lib/scheduler/defer.rb:94:in `block in do_work'
rails_multisite-4.0.1/lib/rails_multisite/connection_management.rb:284:in `with_connection'
rails_multisite-4.0.1/lib/rails_multisite/connection_management.rb:77:in `with_connection'
/var/www/discourse/lib/scheduler/defer.rb:89:in `do_work'
/var/www/discourse/lib/scheduler/defer.rb:79:in `block (2 levels) in start_thread'
