JOURNAL PLUGIN (Not listed in dropdown): Commenting first post creates a journal entry instead of comment
Discourse Version: 2.9beta9
Plugin Commit: i18n: Update translations (#2) · paviliondev/discourse-journal@4b918d7 · GitHub
  1. Create new journal
  2. Comment on first post
  3. A new journal entry is created - even if other users are commenting
See vid:
https://share.cleanshot.com/G7ZkNn
https://forum.cannabisanbauen.net/t/neuer-test-growreport-mit-verbesserter-ansicht-bitte-testen/30412/11
Browser Console log:
Cookie “_plausible_key” with the “SameSite” attribute value “Lax” or “Strict” was omitted because of a cross-site redirect. plausible.hash.js
InstallTrigger is deprecated and will be removed in the future. index.js:21
Deprecation notice: registerOption() from pretty-textis deprecated. Usehelper.registerOptions()instead. (deprecated since Discourse 2.8.0.beta9) (removal in Discourse 2.9.0.beta1) deprecated.js:35 [PLUGIN discourse-category-lockdown] To prevent errors in tests, add apluginIdkey to yourmodifyClasscall. This will ensure the modification is only applied once. 3 plugin-api.js:19 [PLUGIN discourse-journal] To prevent errors in tests, add apluginIdkey to yourmodifyClasscall. This will ensure the modification is only applied once. 11 plugin-api.js:19 [PLUGIN discourse-legal-tools] To prevent errors in tests, add apluginIdkey to yourmodifyClasscall. This will ensure the modification is only applied once. plugin-api.js:19 Some cookies are misusing the recommended “SameSite“ attribute 3 [THEME 148 'Masonry Image Gallery'] To prevent errors in tests, add apluginIdkey to yourmodifyClass` call. This will ensure the modification is only applied once. 2 plugin-api.js:19
Uncaught (in promise) TypeError: category is undefined
html c9a1b5099bea4896cf3fe36fd958b80962a57804.js:130
draw widget.js:513
render widget.js:234
Ember 5
rerenderWidget mount-widget.js:146
invoke backburner.js:351
flush backburner.js:241
flush backburner.js:447
_end backburner.js:999
_boundAutorunEnd backburner.js:648
c9a1b5099bea4896cf3fe36fd958b80962a57804.js:130:17
Uncaught TypeError: t.model is undefined
openCommentCompose journal-post.js:348
invoke backburner.js:353
end backburner.js:729
_runExpiredTimers backburner.js:1136
journal-post.js:348
Uncaught TypeError: t.model is null
6 journal-post.js:348
Quick note: Even after hitting “comment” button in the first post, in the composer it says “Create new entry” instead of “Create new comment”.
Screenshot 2022-10-04 at 13.29.21
You can apply to have the journal plugin added here
Monosnap Discourse Plugin Manager - Manifest of Discourse Plugins with compatibility, support and testing. — Private Browsing 2022-10-06 09-12-16
https://discourse.pluginmanager.org/w/submit-a-plugin
