Issue with the event-rsvp modal
Sharing this report by @jrgong:
The error message:
a36c6e66f01ab0b7697c3703f8860449cf7ae3d7_2_690x244
The post it references:
Next to this one, there are two additional modals to be converted to the new system: discourse-events/assets/javascripts/discourse/templates/modal at main · paviliondev/discourse-events · GitHub
I’m going to mark the plugin as broken on Meta for now.
Are these covered by @angus’ latest fix?
I’m about to update my instance to the latest versions to check it out.
No, that latest fix left three modals in a non working state.
The RSVP modal is working with the latest.
Those are associated with the admin controls, which to my knowledge no-one is using.
Please revert this.
I have removed the “broken” tag from the meta topic.
@angus I have my instance updated and it seems that your fixes have addressed the Ember 5 issues that I had encountered. Thanks so much for your support!
I really appreciate your attention on this. Is there somewhere that I can send you a donation in thanks?
