Import Events with iCalendar
This topic covers import events into Discourse using iCalendar. Here’s a video of me setting that up:
https://www.loom.com/share/87e2b327eed84da688f0aac79c449c37?sid=b449582d-9cca-4cbd-b8ac-7a32e8afbd80
Setting up the source
Click on “Sources” in the Events Plugin admin panel and click “+ Add Source”.
The options you select here will depend on what kind of import and sync you want. Each option has a short description under it, and some of those descriptions will update when you change the selection to give you further details on what your selection means. If you want further information on other options, or help setting up a Source for a specific use case, please reply below or send me a PM.
