Image upload in composer - hitting "Next" should be greyed out
Discourse Version: 3.2.1
Plugin Commit: Merge pull request #290 from paviliondev/add_admin_sidebar_link · paviliondev/discourse-custom-wizard@f066ff9 · GitHub
  1. in composer, upload one or more images
  2. while upload is in progress, hit next
  3. when a new topic is created as action, images are not showing up in post
Stuck as processing in the post created: https://share.cleanshot.com/1DvJmVNY
nothing in logs
Just a note that this will be looked at on late next week by @merefield
thanks for your patience @jrgong this fix has been merged:
hopefully that resolves things for you in this respect.
Please confirm after you’ve updated, had a chance to test and I will mark this as a solution and close the topic.
@richard can you update our instance so we can test it?
I’ve updated staging. We’ll update production after you give us the green light.
It’s better to submit requests like this in our support portal, we’ll see them (much) quicker
