Hi, I was wondering how i can hide or show a field based on a choice in another field?
Say i want to enter a IP address in a text box, but i only want to display this text box if the checkbox DHCP is not selected. How can i achieve this?
So you want to hide a field if a checkbox on the same Wizard step is not selected?
I’m not sure that can be done at present.
You might be able to achieve that using a conditional step or field, where the 2nd step (or field) only displays if that checkbox is not selected. But this isn’t something I’ve tried. I suspect it only works if the step / field in question comes later in the wizard (i.e. can’t be applied to the current / active step in real time).
See this for some more info on conditional settings:
