The journal plugin allows you to keep a “journal” in Discourse, which basically brings an extra level of comments.
After enabling the plugin, you need to enable it on a per-category basis. You must also select one or more groups that are allowed to post a journal.
In the category settings:
- Journal page post: In common Discourse terms this would be the OP or topic post and he’s referring to each topic as a journal page, one that can have multiple journal entries. Create topic button = create new journal page.
- Journal entries: In common Discourse terms this would be a reply post to the OP, but instead we are posting new journal page entries. These appear un-nested as standard replies more or less. Reply button = create new journal entry.
- Journal entry comments: This is what confused me earlier, but it makes total sense in the context of a journal format. He wants the comments on each journal entry nested underneath it. A journal entry can have many comments, but they should all stay under each journal entry in their own timeline regardless of it’s where on the the entry is in the timeline of the journal page (which makes sense!). Nested comments on replies to a topic post.
