Hello
I'm having a problem loading the map when I switch from one map to another.
Explanations: Each map is in a different category
If I change category by category page or by complete URL, everything is OK
The problem occurs if I go through the sidebar. The sidebar uses a partial URL:
Do you have a solution?
Thanks for your great plugin!
--- Problem encountered here:
categories with map: https://forums.ffjdr.org/c/e-irl/14/l/map
