The Groups Widget allows each user to see what groups they are in currently.
Overview
The Layouts Groups Widget each user to see what groups they are in. See the installation guide to learn how to install and administer this widget.
Settings
There are a couple settings that you can configure to customize how the groups widget appears in the layout.
Show Header
Toggle this setting to show/hide the title header in the widget.
Hidden Groups
Select which groups should be hidden from the widget.
Style
The widget comes with some pre-installed theme styles. Select from the options in the dropdown to configure a unique style for the widget.
This works just like I expected it to! Thanks so much!
https://discourse.pluginmanager.org/t/sidebar-widget-for-groups
The themes are a really nice touch! Can we add our own themes or just customize the plugin in general?
Hey @Justin_Vega ,
Yes, on your own instance feel free to customize the appearance by adding any CSS to your main theme or creating a theme component that targets the classes used on the widget. If doing this, Iβd recommend setting the theme setting: style to normal first.
If youβd like to create a theme thatβs available to all, feel free to submit a PR to the theme component . What youβll need is to:
Add your theme as an option in the setting here .
Create a file in /scss/themes with the name of your theme.
Add the conditional around your styles (see other themes for examples)
@if $style == 'yourThemeName' {
// Insert your custom theme styles
Import your theme in /common/common.scss/
angus
August 22, 2022, 7:10am
4
3 posts were split to a new topic: Groups widget creates exception
