Hello, I get an error when I validate step 1. see the attached screenshot
my config:
now I no longer have the error when I validate but I get another error:
after profil update:
my config:
@FuraXx Hey, it looks like the wizard is working correctly. The Refused to load script
error is unconnected with the custom wizard plugin.
The reason you’re seeing t
in the user profile is that you’ve mapped bio_raw
to the checkbox field You are developer
. Checkbox fields are booleans, so t
will show up in the profile if it’s checked.
Hi, I also have this issue and none of my wizards can finish right now.
Opening a wizard, my console gives me CSP errors for http://mydomain.com/pretty-text-bundle.js
and http://mydomain.com/ember_jquery.js
. Both urls get 404 not found by the way.
Clicking the Done button, I get the Doctype error like @FuraXx which disappear after a few seconds. The console trow a 500 Internal Server Error
on a PUT request.
@IwishIcanFLighT Hey, sorry for the slow reply. Are you still getting this error? Are you using the latest version of the plugin?
@angusmcleod Thanks for getting back to me.
Yes I’m still facing the error and my Discourse instance is using the plugin & Discourse versions I mentioned in my previous message (Discourse: 2.9.0.beta3 (fc40a572bb) & plugin: 1.18.4). I believe they both are up-to-date.
Tried on both Firefox and Chrome, same error.
Here’s the 500 error console output:
XHRPUThttps://mydomain.com/w/my-wizard/steps/step_1
[HTTP/2 500 Internal Server Error 290ms]
PUT
État
500
VersionHTTP/2
Transfert0,99 Ko (taille 658 o)
Politique de référentstrict-origin-when-cross-origin
content-length
658
content-type
text/html; charset=utf-8
date
Tue, 12 Apr 2022 09:25:40 GMT
server
openresty
set-cookie
__profilin=*Hidden for privacy*; path=/; secure; HttpOnly; SameSite=Lax
X-Firefox-Spdy
h2
x-request-id
6f3f7bd8-2c0d-4748-8b4d-5c314537ebbc
x-runtime
0.267575
Accept
Accept-Encoding
gzip, deflate, br
Accept-Language
fr,fr-FR;q=0.8,en-US;q=0.5,en;q=0.3
Cache-Control
no-cache
Connection
keep-alive
Content-Length
148
Content-Type
application/x-www-form-urlencoded; charset=UTF-8
Cookie
Host
mydomain.com
Origin
Pragma
no-cache
Referer
Sec-Fetch-Dest
empty
Sec-Fetch-Mode
cors
Sec-Fetch-Site
same-origin
TE
trailers
User-Agent
Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0
X-CSRF-Token
X-Requested-With
XMLHttpRequest
The issue is most likely specific to the wizard you have. Could you please export the wizard seeing this error (in the wizard manager) and PM it to me on coop.pavilion.tech? Thanks.
