Discourse Events either has a bug, or is incompatible with the Discourse commit linked below.
Time: 2024-08-21T00:38:59+00:00
Message: ci / frontend_tests has failed: System.IO.IOException: No space left on device : '/home/runner/runners/2.319.1/_diag/Worker_20240821-001607-utc.log' at System.IO.RandomAccess.WriteAtOffset(SafeFileHandle handle, ReadOnlySpan`1 buffer, Int64 fileOffset) at System.IO.Strategies.BufferedFileStreamStrategy.FlushWrite() at System.IO.StreamWriter.Flush(Boolean flushStream, Boolean flushEncoder) at System.Diagnostics.TextWriterTraceListener.Flush() at GitHub.Runner.Common.HostTraceListener.WriteHeader(String source, TraceEventType eventType, Int32 id) at GitHub.Runner.Common.HostTraceListener.TraceEvent(TraceEventCache eventCache, String source, TraceEventType eventType, Int32 id, String message) at System.Diagnostics.TraceSource.TraceEvent(TraceEventType eventType, Int32 id, String message) at GitHub.Runner.Worker.Worker.RunAsync(String pipeIn, String pipeOut) at GitHub.Runner.Worker.Program.MainAsync(IHostContext context, String[] args) System.IO.IOException: No space left on device : '/home/runner/runners/2.319.1/_diag/Worker_20240821-001607-utc.log' at System.IO.RandomAccess.WriteAtOffset(SafeFileHandle handle, ReadOnlySpan`1 buffer, Int64 fileOffset) at System.IO.Strategies.BufferedFileStreamStrategy.FlushWrite() at System.IO.StreamWriter.Flush(Boolean flushStream, Boolean flushEncoder) at System.Diagnostics.TextWriterTraceListener.Flush() at GitHub.Runner.Common.HostTraceListener.WriteHeader(String source, TraceEventType eventType, Int32 id) at GitHub.Runner.Common.HostTraceListener.TraceEvent(TraceEventCache eventCache, String source, TraceEventType eventType, Int32 id, String message) at System.Diagnostics.TraceSource.TraceEvent(TraceEventType eventType, Int32 id, String message) at GitHub.Runner.Common.Tracing.Error(Exception exception) at GitHub.Runner.Worker.Program.MainAsync(IHostContext context, String[] args) Unhandled exception. System.IO.IOException: No space left on device : '/home/runner/runners/2.319.1/_diag/Worker_20240821-001607-utc.log' at System.IO.RandomAccess.WriteAtOffset(SafeFileHandle handle, ReadOnlySpan`1 buffer, Int64 fileOffset) at System.IO.Strategies.BufferedFileStreamStrategy.FlushWrite() at System.IO.StreamWriter.Flush(Boolean flushStream, Boolean flushEncoder) at System.Diagnostics.TextWriterTraceListener.Flush() at System.Diagnostics.TraceSource.Flush() at GitHub.Runner.Common.TraceManager.Dispose(Boolean disposing) at GitHub.Runner.Common.TraceManager.Dispose() at GitHub.Runner.Common.HostContext.Dispose(Boolean disposing) at GitHub.Runner.Common.HostContext.Dispose() at GitHub.Runner.Worker.Program.Main(String[] args), You are running out of disk space. The runner will stop working when the machine runs out of disk space. Free space left: 10 MB
