Discourse Events main does not work on tests-passed
Discourse Events either has a bug, or is incompatible with the Discourse commit linked below.
Time: 2024-07-05T00:08:19+00:00
Message: can't activate stringio-3.1.1, already activated stringio-3.1.0
SHA: 59b061ccfe86116fabe125416ce6363e2af50a3d
SHA: 9249032c550f41bdc1255d320d71546949bfe197
Backtrace:
/usr/local/lib/ruby/site_ruby/3.3.0/rubygems/specification.rb:2226:in check_version_conflict' /usr/local/lib/ruby/site_ruby/3.3.0/rubygems/specification.rb:1370:in activate’
/var/www/discourse/lib/plugin_gem.rb:25:in load' /var/www/discourse/lib/plugin/instance.rb:808:in gem’
/var/www/discourse/plugins/discourse-events/plugin.rb:26:in activate!' /var/www/discourse/lib/plugin/instance.rb:751:in instance_eval’
/var/www/discourse/lib/plugin/instance.rb:751:in activate!' /var/www/discourse/lib/plugin_guard/extensions/discourse.rb:21:in block in activate_plugins!’
/var/www/discourse/lib/plugin_guard/extensions/discourse.rb:8:in each' /var/www/discourse/lib/plugin_guard/extensions/discourse.rb:8:in activate_plugins!’
/var/www/discourse/config/application.rb:231:in block in <class:Application>' /var/www/discourse/lib/plugin.rb:19:in initialization_guard’
/var/www/discourse/config/application.rb:231:in <class:Application>' /var/www/discourse/config/application.rb:75:in module:Discourse’
/var/www/discourse/config/application.rb:74:in <top (required)>' /usr/local/lib/ruby/3.3.0/bundled_gems.rb:74:in require’
/usr/local/lib/ruby/3.3.0/bundled_gems.rb:74:in block (2 levels) in replace_require' /var/www/discourse/Rakefile:7:in <top (required)>’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/rake_module.rb:29:in load' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/rake_module.rb:29:in load_rakefile’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:740:in raw_load_rakefile' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:126:in block in load_rakefile’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:214:in standard_exception_handling' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:125:in load_rakefile’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:82:in block in run' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:214:in standard_exception_handling’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/lib/rake/application.rb:80:in run' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/exe/rake:27:in <top (required)>’
/var/www/discourse/vendor/bundle/ruby/3.3.0/bin/rake:25:in load' /var/www/discourse/vendor/bundle/ruby/3.3.0/bin/rake:25:in <top (required)>’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.3/lib/bundler/cli/exec.rb:58:in load' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.3/lib/bundler/cli/exec.rb:58:in kernel_load’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.3/lib/bundler/cli/exec.rb:23:in run' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.3/lib/bundler/cli.rb:451:in exec’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.3/lib/bundler/vendor/thor/lib/thor/command.rb:28:in run' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.3/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in invoke_command’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.3/lib/bundler/vendor/thor/lib/thor.rb:527:in dispatch' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.3/lib/bundler/cli.rb:34:in dispatch’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.3/lib/bundler/vendor/thor/lib/thor/base.rb:584:in start' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.3/lib/bundler/cli.rb:28:in start’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.3/exe/bundle:28:in block in <top (required)>' /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.3/lib/bundler/friendly_errors.rb:117:in with_friendly_errors’
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.3/exe/bundle:20:in <top (required)>' /usr/local/bin/bundle:25:in load’
/usr/local/bin/bundle:25:in `’
Interesting, that specific commit of core has 3.1.0
and immediately after they went back to 3.1.1
Discourse Events has recovered from this issue.
