Discourse Events main does not work on tests-passed
Discourse Events either has a bug, or is incompatible with the Discourse commit linked below.
Time: 2023-11-08T00:04:48+00:00
Message: can't activate date-3.3.3, already activated date-3.3.4
SHA: c2b143860a807363f4868c89ac069aac439ff201
SHA: 5e60b42592d68835fa4f4fcec1ed7b79741b884d
Backtrace:
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/specification.rb:2302:in check_version_conflict' /usr/local/lib/ruby/site_ruby/3.2.0/rubygems/specification.rb:1439:in activate’
/var/www/discourse/lib/plugin_gem.rb:25:in load' /var/www/discourse/lib/plugin/instance.rb:827:in gem’
/var/www/discourse/plugins/discourse-events/plugin.rb:23:in activate!' /var/www/discourse/lib/plugin/instance.rb:724:in instance_eval’
/var/www/discourse/lib/plugin/instance.rb:724:in activate!' /var/www/discourse/lib/plugin_guard/extensions/discourse.rb:21:in block in activate_plugins!’
/var/www/discourse/lib/plugin_guard/extensions/discourse.rb:8:in each' /var/www/discourse/lib/plugin_guard/extensions/discourse.rb:8:in activate_plugins!’
/var/www/discourse/config/application.rb:227:in block in <class:Application>' /var/www/discourse/lib/plugin.rb:19:in initialization_guard’
/var/www/discourse/config/application.rb:227:in <class:Application>' /var/www/discourse/config/application.rb:75:in module:Discourse’
/var/www/discourse/config/application.rb:74:in <top (required)>' <internal:/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb>:38:in require’
internal:/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb:38:in require' /var/www/discourse/Rakefile:7:in <top (required)>’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/rake_module.rb:29:in load' /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/rake_module.rb:29:in load_rakefile’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:734:in raw_load_rakefile' /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:126:in block in load_rakefile’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:208:in standard_exception_handling' /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:125:in load_rakefile’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:82:in block in run' /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:208:in standard_exception_handling’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:80:in run' /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/exe/rake:27:in <top (required)>’
/var/www/discourse/vendor/bundle/ruby/3.2.0/bin/rake:25:in load' /var/www/discourse/vendor/bundle/ruby/3.2.0/bin/rake:25:in <top (required)>’
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/cli/exec.rb:58:in load' /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/cli/exec.rb:58:in kernel_load’
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/cli/exec.rb:23:in run' /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/cli.rb:492:in exec’
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/vendor/thor/lib/thor/command.rb:27:in run' /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in invoke_command’
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/vendor/thor/lib/thor.rb:392:in dispatch' /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/cli.rb:34:in dispatch’
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/vendor/thor/lib/thor/base.rb:485:in start' /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/cli.rb:28:in start’
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/exe/bundle:45:in block in <top (required)>' /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/friendly_errors.rb:117:in with_friendly_errors’
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/exe/bundle:33:in <top (required)>' /usr/local/bin/bundle:25:in load’
/usr/local/bin/bundle:25:in `’
Can someone please review @development_team
Merged :+1:
Discourse Events has recovered from this issue.
