Discourse Custom Wizard main does not work on tests-passed
Discourse Custom Wizard either has a bug, or is incompatible with the Discourse commit linked below.
Time: 2025-01-02T00:08:27+00:00
Message: ci / frontend_tests has failed: ubuntu-latest pipelines will use ubuntu-24.04 soon. For more details, see https://github.com/actions/runner-images/issues/10636, QUnit Test Failure: Global error: Uncaught Error: Unhandled request in test environment: /admin/config/user_fields (GET) at http://localhost:7357/assets/chunk.975bee7d60f942cde4ea.d41d8cd9.js, line 229863, Process completed with exit code 1.
Hey guys, any idea when this will be fixed? I tested on a staging site and this does seem to be an issue as the wizard fields are not displaying. Can’t seem to find any errors related to this.
Not sure if this topic is being monitored, so mentioning @angus here. Sorry to bug, but I really need to rebuild for other issues and it seems the wizard is broken. Thanks!
Discourse Custom Wizard has recovered from this issue.
@davidkingham Sorry for the slow response David, this got lost over the holiday period. The automatic resolution of this issue is indeed correct. I’ve confirmed the plugin is working on the latest version of Discourse. The failure was a non-critical tests failure (which has been resolved).
