Discourse Custom Wizard main does not work on tests-passed
Discourse Custom Wizard either has a bug, or is incompatible with the Discourse commit linked below.
Time: 2023-11-16T00:07:42+00:00
Message: ci / frontend_tests has failed: QUnit Test Failure: Acceptance: Field | Fields: Composer - Hyperlink, Process completed with exit code 1.
Re-ran the tests, still failing.
Ah so this is not my PR! It’s failing in my PR too. (Which was holding up the PR!)
If I solve this for my PR and it is merged this issue will be resolved
I believe I know why this is happening, and it’s down to an unresolved deprecation which is causing the composer banner not to appear.
I’m on it.
No, that’s only part of it.
It’s because of the new Glimmer Composer with Topic Template functionality I suspect … still looking.
This is all fixed as part of my huge PR:
Discourse Custom Wizard has recovered from this issue.
