system
1
Discourse Custom Wizard either has a bug, or is incompatible with the Discourse commit linked below.
Time: 2023-11-07T00:13:09+00:00
Message: ci / backend_tests has failed: Process completed with exit code 1.
@development_team - is this a problem?
Usually it’s a matter of going into github and restarting the test. Going to do that right now.
Nope, tests keep failing, changing this to issue
1) CustomWizard::UpdateValidator doesn't validate date time field if the format is not respected
Failure/Error: updater.validate
NoMethodError:
undefined method `ctx_load' for PrettyText:Module
# ./plugins/discourse-custom-wizard/lib/custom_wizard/validators/update.rb:131:in `v8'
# ./plugins/discourse-custom-wizard/lib/custom_wizard/validators/update.rb:94:in `validate_date'
# ./plugins/discourse-custom-wizard/lib/custom_wizard/validators/update.rb:57:in `validate_field'
# ./plugins/discourse-custom-wizard/lib/custom_wizard/validators/update.rb:13:in `block in perform'
# ./plugins/discourse-custom-wizard/lib/custom_wizard/validators/update.rb:12:in `each'
# ./plugins/discourse-custom-wizard/lib/custom_wizard/validators/update.rb:12:in `perform'
# ./plugins/discourse-custom-wizard/lib/custom_wizard/step_updater.rb:44:in `validate'
# ./plugins/discourse-custom-wizard/spec/components/custom_wizard/update_validator_spec.rb:16:in `perform_validation'
# ./plugins/discourse-custom-wizard/spec/components/custom_wizard/update_validator_spec.rb:180:in `block (2 levels) in <main>'
# ./spec/rails_helper.rb:485:in `block (3 levels) in <top (required)>'
# ./spec/rails_helper.rb:480:in `block (2 levels) in <top (required)>'
# ./spec/rails_helper.rb:469:in `block (2 levels) in <top (required)>'
2) CustomWizard::UpdateValidator validates date time fields
NoMethodError:
# ./plugins/discourse-custom-wizard/spec/components/custom_wizard/update_validator_spec.rb:170:in `block (2 levels) in <main>'
3) CustomWizard::UpdateValidator doesn't validate date field if the format is not respected
NoMethodError:
# ./plugins/discourse-custom-wizard/spec/components/custom_wizard/update_validator_spec.rb:160:in `block (2 levels) in <main>'
4) CustomWizard::UpdateValidator validates date fields
NoMethodError:
# ./plugins/discourse-custom-wizard/spec/components/custom_wizard/update_validator_spec.rb:150:in `block (2 levels) in <main>'
system
7
Discourse Custom Wizard has recovered from this issue.
