system
June 1, 2023, 12:08am
1
Discourse Custom Wizard either has a bug, or is incompatible with the Discourse commit linked below.
Time: 2023-06-01T00:08:30+00:00
Message: ci / backend_tests has failed: Process completed with exit code 1.
Hmm
1) CustomWizard::Mapper interpolates avatar with valid size
Failure/Error:
expect(CustomWizard::Mapper.new(
inputs: avatar_inputs,
data: data,
user: user1
).perform).to eq("Avatar: })")
expected: "Avatar: "
got: "Avatar: "
(compared using ==)
# ./plugins/discourse-custom-wizard/spec/components/custom_wizard/mapper_spec.rb:286:in `block (3 levels) in <main>'
# ./spec/rails_helper.rb:372:in `block (3 levels) in <top (required)>'
# ./spec/rails_helper.rb:367:in `block (2 levels) in <top (required)>'
# ./spec/rails_helper.rb:356:in `block (2 levels) in <top (required)>'
Caused by https://github.com/discourse/discourse/commit/c2332d7505379c30e11d295d90f5224385736993
3.Our default avatar sizes are now “24|48|72|96|144|288” these sizes were
very specifically picked to limit amount of bluriness introduced by webkit.
Our avatars are already blurry due to 1px border, so this corrects old blur.
system
June 2, 2023, 10:58am
3
Discourse Custom Wizard has recovered from this issue.
