Moved from Github issue #15
sociocracyforall commented on May 13, 2021
Having an error every time a language isn’t set is a bit inconvenient for the user (and the error is currently not user readable).
Often a forum may have a lingua franca, but still want to require language tags be set.
Having a default language tag seems like a great feature.
Could this be added?
If coding it, where would one put it?
(I’m not much of a coder myself but may be able to bring in some support
Contributor
vccoffey commented on Jul 26, 2021
Under the “require language tag” setting, add an additional setting: “if no language tag is selected, add default language tag”
The default language tag can auto detected from post
add a flash (or popup?) message informing the user that the language tag was added
