When I am making a custom wizard how can I set it up to where whenever a user navigates to it, it automatically fills/shows the data which they entered into it before so that they can update/edit some parts if they want? Obviously I must have the Users can submit multiple times. setting toggled on, but is there anything else I should do? I am looking to integrate this plugin as a core and critical part of my research lab and probably eventually purchase a subscription to it, however this feature would be absolutely necessary for us and it isn’t exactly clear to me how I can achieve it.
Update:
I have played around with this plugin and I really love it. I can set up a Data Explorer query to retrieve a particular user’s submission, which is half of what I needed. This is really fantastic work. That being said, would it require a subscription or a feature request for a particular wizard to autofill with a particular user’s previous submission? After playing around with the plugin, it seems like such a thing isn’t supported by default
