I may have spoke a bit too soon actually, unfortunately if I visit the onboarding wizard URL, it returns a blank wizard. (https://anomicforum.xyz/w/onboarding)
Image: (trust level limit )coop.pavilion.tech/uploads/db3994/original/2X/8/89f5efa8cbae1d1d0423ac6fb1523ea056f080d0.png
POLYFILL => User Agent Browser: Chrome, Version: 130.0.0.0
chunk.bb22b247b452b93be801.d41d8cd9.js:1 ℹ️ Discourse v3.4.0.beta3-dev — https://github.com/discourse/discourse/commits/216845e4c7 — Ember v5.5.0
composer.js:874 Deprecation notice: [discourse/plugins/discourse-custom-wizard/discourse/templates/components/custom-wizard-composer-editor] Overriding component templates is deprecated, and will soon be disabled. Use plugin outlets, CSS, or other customization APIs instead. [deprecation id: discourse.component-template-overrides] [info: https://meta.discourse.org/t/247487]
a @ composer.js:874Understand this warningAI
composer.js:874 Deprecation notice: [discourse/plugins/discourse-custom-wizard/discourse/templates/components/custom-wizard-date-input] Overriding component templates is deprecated, and will soon be disabled. Use plugin outlets, CSS, or other customization APIs instead. [deprecation id: discourse.component-template-overrides] [info: https://meta.discourse.org/t/247487]
composer.js:874 Deprecation notice: [discourse/plugins/discourse-custom-wizard/discourse/templates/components/custom-wizard-date-time-input] Overriding component templates is deprecated, and will soon be disabled. Use plugin outlets, CSS, or other customization APIs instead. [deprecation id: discourse.component-template-overrides] [info: https://meta.discourse.org/t/247487]
composer.js:874 Deprecation notice: [discourse/plugins/discourse-custom-wizard/discourse/templates/components/custom-wizard-time-input] Overriding component templates is deprecated, and will soon be disabled. Use plugin outlets, CSS, or other customization APIs instead. [deprecation id: discourse.component-template-overrides] [info: https://meta.discourse.org/t/247487]
composer.js:874 Deprecation notice: [discourse/plugins/discourse-custom-wizard/discourse/templates/components/wizard-subscription-selector/wizard-subscription-selector-header] Overriding component templates is deprecated, and will soon be disabled. Use plugin outlets, CSS, or other customization APIs instead. [deprecation id: discourse.component-template-overrides] [info: https://meta.discourse.org/t/247487]
composer.js:874 Deprecation notice: [discourse/plugins/discourse-custom-wizard/discourse/templates/components/wizard-subscription-selector/wizard-subscription-selector-row] Overriding component templates is deprecated, and will soon be disabled. Use plugin outlets, CSS, or other customization APIs instead. [deprecation id: discourse.component-template-overrides] [info: https://meta.discourse.org/t/247487]
composer.js:874 Deprecation notice: [discourse/plugins/discourse-custom-wizard/discourse/templates/components/wizard-user-chooser/wizard-user-chooser-row] Overriding component templates is deprecated, and will soon be disabled. Use plugin outlets, CSS, or other customization APIs instead. [deprecation id: discourse.component-template-overrides] [info: https://meta.discourse.org/t/247487]
composer.js:874 Deprecation notice: [discourse/plugins/discourse-follow/discourse/templates/components/follow-post-stream] Overriding component templates is deprecated, and will soon be disabled. Use plugin outlets, CSS, or other customization APIs instead. [deprecation id: discourse.component-template-overrides] [info: https://meta.discourse.org/t/247487]
formatter.js:383 [THEME 78 'Topic List Like Column'] To prevent errors in tests, add a `pluginId` key to your `modifyClass` call. This will ensure the modification is only applied once.
eB @ formatter.js:383Understand this warningAI
4 POLYFILL => User Agent Browser: Chrome, Version: 130.0.0.0
But, if I go directly to the wizard step, I get this: (https://anomicforum.xyz/w/onboarding/steps/step_5)
[PLUGIN discourse-custom-wizard-78f901a5694e3b70f811319fec6c198628c6e4a51747d2721728b5a509b92d9a] TypeError: Cannot read properties of undefined (reading 'completed')
at e.afterModel (custom-wizard-step.js:27:1)
at A.runAfterModelHook (router_js.js:720:1)
at router_js.js:630:1
at _ (rsvp.js:434:1)
at y (rsvp.js:420:1)
at invoke (backburner.js.js:282:1)
at d.flush (backburner.js.js:197:1)
at p.flush (backburner.js.js:358:1)
at B._end (backburner.js.js:798:1)
at B.end (backburner.js.js:589:1)
at B._run (backburner.js.js:842:1)
at B.run (backburner.js.js:624:1)
at index.js:75:1
at Object.success (video-placeholder.js:19:1)
at l (jquery.js:10:1)
at Object.fireWith [as resolveWith] (jquery.js:10:1)
at T (jquery.js:10:1)
at XMLHttpRequest.<anonymous> (jquery.js:10:1)
error @ topic.js:392
T @ router.js:1218
triggerEvent @ router.js:234
trigger @ router_js.js:438
transitionDidError @ router.js:267
(anonymous) @ router_js.js:253
_ @ rsvp.js:434
y @ rsvp.js:420
m @ rsvp.js:369
invoke @ backburner.js.js:282
flush @ backburner.js.js:197
flush @ backburner.js.js:358
_end @ backburner.js.js:798
end @ backburner.js.js:589
_run @ backburner.js.js:842
run @ backburner.js.js:624
(anonymous) @ index.js:75
(anonymous) @ video-placeholder.js:19
l @ jquery.js:10
fireWith @ jquery.js:10
T @ jquery.js:10
(anonymous) @ jquery.js:10
load
send @ jquery.js:10
ajax @ jquery.js:10
_ @ video-placeholder.js:19
(anonymous) @ rsvp.js:457
k @ rsvp.js:913
T @ video-placeholder.js:19
e.findCustomWizard @ custom-wizard.js:98
model @ custom-wizard.js:20
deserialize @ route.js:596
getModel @ router_js.js:793
(anonymous) @ router_js.js:627
_ @ rsvp.js:434
y @ rsvp.js:420
(anonymous) @ backburner.js.js:523
Promise.then
(anonymous) @ backburner.js.js:26
flush @ index.js:40
_scheduleAutorun @ backburner.js.js:964
_ensureInstance @ backburner.js.js:955
schedule @ backburner.js.js:648
(anonymous) @ index.js:167
waitForDOMReady @ index.js:343
init @ index.js:251
b @ core.js:77
create @ core.js:401
(anonymous) @ start-app.js:4
b @ osano.js:2
value @ osano.js:2
(anonymous) @ discourse-boot.js:13
Show 6 more frames
Show lessUnderstand this errorAI
router.js:1141 Error while processing route: customWizardStep Cannot read properties of undefined (reading 'completed') TypeError: Cannot read properties of undefined (reading 'completed')
at e.afterModel (https://anomicforum.xyz/assets/plugins/discourse-custom-wizard-78f901a5694e3b70f811319fec6c198628c6e4a51747d2721728b5a509b92d9a.js:613:55)
at A.runAfterModelHook (https://anomicforum.xyz/assets/vendor.d3163860318024d1a45415fcf58dbe4b-f6a0e31af09bc94252ffd2005ded43e70ee5ea44cbc0d90b36967a66fdf76b72.js:11:394672)
at https://anomicforum.xyz/assets/vendor.d3163860318024d1a45415fcf58dbe4b-f6a0e31af09bc94252ffd2005ded43e70ee5ea44cbc0d90b36967a66fdf76b72.js:11:393376
at _ (https://anomicforum.xyz/assets/vendor.d3163860318024d1a45415fcf58dbe4b-f6a0e31af09bc94252ffd2005ded43e70ee5ea44cbc0d90b36967a66fdf76b72.js:11:412767)
at y (https://anomicforum.xyz/assets/vendor.d3163860318024d1a45415fcf58dbe4b-f6a0e31af09bc94252ffd2005ded43e70ee5ea44cbc0d90b36967a66fdf76b72.js:11:412659)
at invoke (https://anomicforum.xyz/assets/vendor.d3163860318024d1a45415fcf58dbe4b-f6a0e31af09bc94252ffd2005ded43e70ee5ea44cbc0d90b36967a66fdf76b72.js:11:358129)
at d.flush (https://anomicforum.xyz/assets/vendor.d3163860318024d1a45415fcf58dbe4b-f6a0e31af09bc94252ffd2005ded43e70ee5ea44cbc0d90b36967a66fdf76b72.js:11:357206)
at p.flush (https://anomicforum.xyz/assets/vendor.d3163860318024d1a45415fcf58dbe4b-f6a0e31af09bc94252ffd2005ded43e70ee5ea44cbc0d90b36967a66fdf76b72.js:11:358969)
at B._end (https://anomicforum.xyz/assets/vendor.d3163860318024d1a45415fcf58dbe4b-f6a0e31af09bc94252ffd2005ded43e70ee5ea44cbc0d90b36967a66fdf76b72.js:11:364052)
at B.end (https://anomicforum.xyz/assets/vendor.d3163860318024d1a45415fcf58dbe4b-f6a0e31af09bc94252ffd2005ded43e70ee5ea44cbc0d90b36967a66fdf76b72.js:11:361145)
at B._run (https://anomicforum.xyz/assets/vendor.d3163860318024d1a45415fcf58dbe4b-f6a0e31af09bc94252ffd2005ded43e70ee5ea44cbc0d90b36967a66fdf76b72.js:11:364566)
at B.run (https://anomicforum.xyz/assets/vendor.d3163860318024d1a45415fcf58dbe4b-f6a0e31af09bc94252ffd2005ded43e70ee5ea44cbc0d90b36967a66fdf76b72.js:11:361689)
at https://anomicforum.xyz/assets/vendor.d3163860318024d1a45415fcf58dbe4b-f6a0e31af09bc94252ffd2005ded43e70ee5ea44cbc0d90b36967a66fdf76b72.js:11:216549
at Object.success (https://anomicforum.xyz/assets/chunk.bb22b247b452b93be801.d41d8cd9.js:54:5676)
at l (https://anomicforum.xyz/assets/chunk.bb22b247b452b93be801.d41d8cd9.js:131:24965)
at Object.fireWith [as resolveWith] (https://anomicforum.xyz/assets/chunk.bb22b247b452b93be801.d41d8cd9.js:131:25709)
at T (https://anomicforum.xyz/assets/chunk.bb22b247b452b93be801.d41d8cd9.js:131:77180)
at XMLHttpRequest.<anonymous> (https://anomicforum.xyz/assets/chunk.bb22b247b452b93be801.d41d8cd9.js:131:79634)
(anonymous) @ router.js:1141
error @ router.js:1091
T @ router.js:1232
_ @ rsvp.js:434
y @ rsvp.js:420
m @ rsvp.js:369
l @ jquery.js:10
T @ jquery.js:10
load
send @ jquery.js:10
ajax @ jquery.js:10
k @ rsvp.js:913
_ @ rsvp.js:434
y @ rsvp.js:420
Promise.then
flush @ index.js:40
init @ index.js:251
b @ core.js:77
b @ osano.js:2
value @ osano.js:2
Show 6 more frames
discourse-tag-banners.js:96 Uncaught TypeError: Cannot read properties of undefined (reading 'tag_id')
at get shouldRender (discourse-tag-banners.js:96:38)
at Te (index.js:1682:1)
at reference.js:164:1
at reference.js:125:1
at validator.js:622:1
at h (reference.js:124:1)
at runtime.js:2074:1
at Object.evaluate (runtime.js:2038:1)
at Object.evaluate (runtime.js:1052:1)
at It.evaluateSyscall (runtime.js:4204:1)
at It.evaluateInner (runtime.js:4175:1)
at It.evaluateOuter (runtime.js:4168:1)
at Wt.next (runtime.js:4999:1)
at Wt._execute (runtime.js:4986:1)
at Wt.execute (runtime.js:4979:1)
at Qt.sync (runtime.js:5046:1)
at dr.render (index.js:4672:1)
at index.js:4934:1
at Nt (runtime.js:4080:1)
at gr._renderRoots (index.js:4916:1)
at gr._renderRootsTransaction (index.js:4960:1)
at gr._renderRoot (index.js:4905:1)
at gr._appendDefinition (index.js:4830:1)
at gr.appendOutletView (index.js:4820:1)
at index.js:75:1
get shouldRender @ discourse-tag-banners.js:96
Te @ index.js:1682
(anonymous) @ reference.js:164
(anonymous) @ reference.js:125
(anonymous) @ validator.js:622
h @ reference.js:124
(anonymous) @ runtime.js:2074
(anonymous) @ runtime.js:2038
evaluate @ runtime.js:1052
evaluateSyscall @ runtime.js:4204
evaluateInner @ runtime.js:4175
evaluateOuter @ runtime.js:4168
next @ runtime.js:4999
_execute @ runtime.js:4986
execute @ runtime.js:4979
sync @ runtime.js:5046
(anonymous) @ index.js:4672
(anonymous) @ index.js:4934
Nt @ runtime.js:4080
_renderRoots @ index.js:4916
_renderRootsTransaction @ index.js:4960
_renderRoot @ index.js:4905
_appendDefinition @ index.js:4830
appendOutletView @ index.js:4820
l @ jquery.js:10
T @ jquery.js:10
load
send @ jquery.js:10
ajax @ jquery.js:10
k @ rsvp.js:913
_ @ rsvp.js:434
y @ rsvp.js:420
Promise.then
flush @ index.js:40
init @ index.js:251
b @ core.js:77
b @ osano.js:2
value @ osano.js:2
Show 6 more frames
at index.js:4934:1
at gr._revalidate (index.js:4992:1)
at invoke (backburner.js.js:280:1)
at index.js:75:1
Te @ index.js:1682
_revalidate @ index.js:4992
invoke @ backburner.js.js:280
l @ jquery.js:10
T @ jquery.js:10
load
send @ jquery.js:10
ajax @ jquery.js:10
k @ rsvp.js:913
#Jn @ chat-api.js:574
listCurrentUserChannels @ chat-api.js:294
(anonymous) @ chat.js:166
loadChannels @ chat.js:165
(anonymous) @ chat-setup.js:128
eH @ formatter.js:383
m @ chat-setup.js:30
initialize @ chat-setup.js:179
(anonymous) @ chunk.bb22b247b452b93be801.d41d8cd9.js:1
(anonymous) @ index.js:145
(anonymous) @ dag-map.js:191
(anonymous) @ dag-map.js:120
(anonymous) @ dag-map.js:66
(anonymous) @ dag-map.js:72
_runInitializer @ index.js:158
runInstanceInitializers @ index.js:143
_bootSync @ instance.js:86
didBecomeReady @ index.js:602
Show 6 more frames
discourse-tag-banners.js:96 Uncaught (in promise) TypeError: Cannot read properties of undefined (reading 'tag_id')
at index.js:4934:1
at backburner.js.js:523:1
Te @ index.js:1682
Promise.then
flush @ index.js:40
_end @ backburner.js.js:804
Promise.then
flush @ index.js:40
Promise.then
flush @ index.js:40
ensureInstance @ backburner.js.js:767
scheduleRevalidate @ index.js:3337
dirtyTag @ validator.js:368
R @ validator.js:440
M @ index.js:485
D @ index.js:521
Ae @ index.js:1796
Ce @ index.js:1772
set @ observable.js:23
subscribe @ composer.js:874Understand this errorAI
3discourse-tag-banners.js:96 Uncaught TypeError: Cannot read properties of undefined (reading 'tag_id')
at index.js:4934:1
at B._join (backburner.js.js:819:1)
at B.join (backburner.js.js:629:1)
at l (index.js:81:1)
at HTMLDocument.<anonymous> (index.js:118:1)
Te @ index.js:1682
_join @ backburner.js.js:819
join @ backburner.js.js:629
l @ index.js:81
(anonymous) @ index.js:118Understand this errorAI
VM691 content-scripts.js:1 POLYFILL => User Agent Browser: Chrome, Version: 130.0.0.0
VM697 content-scripts.js:1 POLYFILL => User Agent Browser: Chrome, Version: 130.0.0.0
VM702 content-scripts.js:1 POLYFILL => User Agent Browser: Chrome, Version: 130.0.0.0
VM709 content-scripts.js:1 POLYFILL => User Agent Browser: Chrome, Version: 130.0.0.0
42discourse-tag-banners.js:96 Uncaught TypeError: Cannot read properties of undefined (reading 'tag_id')
at index.js:4934:1
