I have a quick question, I’m wondering I can create groups with the Wizard Plugin, but they always seem to be closed and there are no members in the group.
I can repro this from my own mini Group creation wizard.
Despite this submission, no members are added and the Group begins Closed:
We will have to look into this and revert.
Thank you for the report.
Fix is on its way, I’ll let you know when it is merged:
Thank you very much Merefield
@philipp was asking for a sample Create Group wizard, does anyone know of a good template?
@Bhanu Maybe you could share the Create Group template we use on projects. And maybe add it to the documentation? When you have time.
Sure, will do
@philipp this has been merged.
Please update your CW and let us know if we can close this issue.
It’s working thanks for the fast fix
Thanks, I’ll close.
