we only disabled non-staff emails. Since the account has admin, you should be able to reset PW. can you try? Otherwise communiteq/richard needs to check. Will let them know.
@Jrgong The issue here is being caused by the mentionables integration. An exception in that causes other javascript to stop running, which is why it wasn’t showing up for me in other contexts. I’ll fix that today.
@Jrgong@richard I’ve pushed fixes for this issue, which is a “compatibility issue” (i.e. Discourse has changed) to the Custom Wizard Plugin and the Mentionables Plugin. The fixes are specifically looking to fix the exception per se. I haven’t tested the mentionables integration itself with the new changes to discourse/discourse thoroughly as I want to ensure this issue is addressed first. That integration should work, but that may also require further work.
note. Also moved this to mentionables, as it’s more a mentionables issue than a CW issue.
