Beginner questions
I just started using this plugin and I can’t seem to get it working.
Issues
I have a very basic wizard and wanted to test somethings
  1. For some reason when I place tags manually in many forms and save the wizard, they’re gone after:
  2. When I test the wizard, there’s no failures in my logs but the tag tracking doesn’t update under my account preferences
I do want to build more complex logic later, for ex.
I want to have a field that takes a list of tags from a tag group, watch the tags that are selected and mute the tags that were not.
I already attempted to build that but it failed for reasons I believe 1. causes.
Questions
  1. Can I use the text type and use field interpolation to represent values?
Full wizard
I’m having the same issue with tags, except on the Create Topic action. I’ve previously made forms and the tags field persists, but not anymore.
