At present, you can restrict an entire Wizard to a group (or groups) via the Permitted / set Subscriber Feature in the Wizard settings.
The problem is that I cannot differentiate between those in a group and those not, except at the point of entry. This limits the utility of this feature.
Use-case:
I am using a wizard to replace the + New Topic button in my category of interest. @myspecialgroup ‘own’ the category. There are 2 subcategories, secure
and read-only.
For members of @myspecialgroup I want it to guide people into posting to either the category or the correct subcategory
For non-members, I want it to guide them to post in the category itself, with a tag.
To achieve this, I need to be able to determine step conditionality based upon group membership.
Suggestion
That the current [set group] functionality of the
Permittedsection in the Wizard settings subscriber features be also applied very similarConditionin the Steps and Fields sections -
That
PermittedandConditionare given the same name to bring it into line with the other sections.
