richard
1
See this topic https://coop.pavilion.tech/t/custom-wizard-support/1360
Template does
{%-if "w{step_1_field_3}" == "" -%}
where step_1_field_3
is an upload field.
Crashes here in lib/custom_wizard/mapper.rb
line 257
if opts[:template] && CustomWizard::Subscription.subscribed?
template = Liquid::Template.parse(string)
string = template.render(data)
end
Changing it to
{%-if "w{step_1_field_3.id}" == "" -%}
resolves this.
I have tried to force an error in other ways, but couldn’t find those.
I guess a quick fallback safeguard for this would just be a matter of
template = Liquid::Template.parse(string) rescue "There is an error in your template"
although it would be better if we were able to do a check for this at the moment the wizard is being saved by the admin.
@angus could you add a check or an exception handler so that it doesn’t error 500 ?
angus
4
There is actually already a check for liquid formatting when the template is saved
The issue here is the interpolation of the object into the output. For review
