5 - Automation and Management
Once you’ve set up a provider, source and connection you may want to automate your imports and syncs or manage your events.
Automation
You can schedule source imports and connection syncs to happen automatically using these site settings
  • update events automatically
  • update events automatically period mins
Note that you’ll need to restart your Discourse server if you change update events automatically period mins.
Event Management
You can manage the events you’ve imported in the “Events” admin tab.
You can delete events you’ve imported, and also their associated topics from this tab.
You can also review the logs of provider authentication, source imports and connection syncs in the “Logs” tab.
